Henrik Sönnerlind
COMSOL Employee
1 year ago
05.07.2023, 09:18 GMT-4
Two possible causes that immediately comes to my mind:
The material model is used outside its stable region. For example, a Linear Elastic Material is sensitive to large compressive strains, as discussed in the section Geometric Nonlinearity in https://www.comsol.com/blogs/modeling-linear-elastic-materials-how-difficult-can-it-be .
You may then need to use a material model that can represent the actual physics better.
There is a 'pull-in' instability (the resisting force in the solid increases slower than the attractive force between the magnets). In that case, you would need to use an auxiliary sweep while applying some type of displacement control.
It may even be a ccombination of the two.
Henrik Sönnerlind
COMSOL
1. The material model is used outside its stable region. For example, a Linear Elastic Material is sensitive to large compressive strains, as discussed in the section Geometric Nonlinearity in .
2. There is a 'pull-in' instability (the resisting force in the solid increases slower than the attractive force between the magnets). In that case, you would need to use an auxiliary sweep while applying some type of displacement control.
1 year ago
19.07.2023, 02:13 GMT-4
Hello
Thank you for your help. Regarding point 1, I tried to use mixed formulation but it did not improve the problem. I understand in this case, that I should try a hyperelastic model (such as Mooney-Rivlin), but I don't have this subnode available- do these models require any extra add-ons?
Regarding point 2, I am not sure if I understand that. The study is time-independent so I don't know how a resisting force can increase "slower". Also, what type of displacement control should I use to ameliorate that? Should I restrict certain boundaries to move only along a defined axis?
Kind Regards, Piotr
Hello
Kind Regards, Piotr
