23.10.2012, 01:28 GMT-4
if you do not change the geometry you can add several parameters to sweep under the Solver node continuation tab, check the doc
23.10.2012, 18:23 GMT-4
thanks Ivar,
I tried to do so and added two parametric sweeps under one study but it only counts for one of them.
thanks for your help
ASAL
thanks Ivar,
ASAL
24.10.2012, 00:58 GMT-4
I'm not sure if the option is there in 4.2 => Sweep type: Specific combination, or All combination, that might be your issue
05.11.2012, 21:39 GMT-5
thanks Ivar, that has been solved, I was making a silly mistake.
just another question: I put a time dependent water temperature as my inlet temperature at the inlet of pipe but now need to change it to heat flux (W/m) but do not get reasonable answer for that. have you got any hint regarding this issue?
thanks for all your help
ASAL
ASAL
06.11.2012, 00:41 GMT-5
if you add a "t" you are adding some multiplier in "seconds" so you whould write 300[K]+4[K/s]*t as t has y default units of [s] the unit issue would be right
But I didnt catch yu heat flux issue, I need to understand in which dimensions you are worling to. You can change your temp boundary to a heat flux boundary and put a time dependent heat flux
