point graph export problem
No problem exporting line graphs.
When exporting point graph I get a message: error unknown property: spacevars?!
thanks
DAvid
2 Replies Last Post 15.02.2013, 08:24 GMT-5
Niklas Rom COMSOL Employee
Posted: 1 decade ago 17.10.2012, 11:00 GMT-4
I would suggest you send the mph file to support@comsol.com.
Niklas Rom
COMSOL
I would suggest you send the mph file to support@comsol.com. Niklas Rom COMSOL
Posted: 1 decade ago 15.02.2013, 08:24 GMT-5
Hello all,
I am also experiencing this export error with 4.3. For me it looks like a bug...
Whatever it is, there is another way (which works!) to export point data:
Derived value>point evaluation>click the point (if it does not exist you'll have to create it under geometry and re-run the model (unfortunately)) and choose the expression to evaluate>evaluate
Then you can copy/paste or export the table...
That works to plot an expression versus time (for time-dependant) or versus parameter value (parametric sweep)
Hope that helps.
David
Hello all, I am also experiencing this export error with 4.3. For me it looks like a bug... Whatever it is, there is another way (which works!) to export point data: Derived value>point evaluation>click the point (if it does not exist you'll have to create it under geometry and re-run the model (unfortunately)) and choose the expression to evaluate>evaluate Then you can copy/paste or export the table... That works to plot an expression versus time (for time-dependant) or versus parameter value (parametric sweep) Hope that helps. David
