Deposition rate using particle tracing module
I have modeled a reactor using the "fluid flow" and "particle tracing module". A substrate wafer is placed across the flow channel. I have implemented the boundary condition so that whenever a particle hits the wafer, it get stick/freeze with the wafer wall.
Now, If I want to calculate how many particles are stick with the wafer wall and rate of deposition from the result section, how I am supposed to do that?
Thank you.
Rokib
1 Reply Last Post 23.07.2013, 12:32 GMT-4
Hello Md Rokibul Islam
Posted: 1 decade ago 23.07.2013, 12:32 GMT-4
Hi Rokibul,
Did you find the answer to your question. I am thinking of modeling my chemical vapor deposition process on similar lines.
Thank you,
Sanket
Hi Rokibul, Did you find the answer to your question. I am thinking of modeling my chemical vapor deposition process on similar lines. Thank you, Sanket
