Monitoring multiple convergence plots (or probes) in cluster sweep (distribute parametric sweep)
Hello, I'm COMSOL newbie working on cluster computing.
I'm using distributed parametric sweep mode, in which each server node solves a single problem (ex. Node 1 - Inlet fluid velocity 1m/s, Node 2 - Inlet fluid velocity 2m/s etc...)
In distributed parametric sweep mode, (1) I want to monitor multiple convergence plots since multiple problems are solving simultaneously. But I can only monitor a single convergence plot... Please give me an advice.
(2) How can I monitor multiple probe plots (which is Probe parameter - Iteration number plots)? I can only monitor accumulated probe table, which is the final converged value. But I want to check the probe value trend with respect to iteration number.
Thank you very much!!! Every comment is my energy please help me!
0 Replies Last Post 05.02.2023, 21:34 GMT-5
Hello Young Jin Lee
