27.09.2012, 08:25 GMT-4
If anybody has any tips for running a time discrete solver model that may help as well.
But there has to be a way to access a previous time step value of a dependent variable during processing. The values are saved because I can view them in post processing.
27.09.2012, 09:43 GMT-4
you have this reference, old but still valid
www.comsol.eu/support/knowledgebase/1042/
but also check "Help " Operators - Special Operators prev() (or BDF if applicable)
You can also search on the FORUM, it has been discussed several times ;)
you have this reference, old but still valid http://www.comsol.eu/support/knowledgebase/1042/
27.09.2012, 10:25 GMT-4
you have this reference, old but still valid www.comsol.eu/support/knowledgebase/1042/
Hi Ivar,
Thank you for the reply. I searched the forum but could not find anything useful for a time-dependent solver. I may have found a work around, however.
I set the time step to be strictly 0.01s (this may change if I find it is not accurate enough) and use the Tt value (slope of Temperature at that time step). By multiplying 0.01 [s] by Tt, this should give delta T for the last time step.
Does this make sense to you? At first glance it seems to be returning correct delta T values, but more investigation is needed before I can say definitively.
[QUOTE]
[/QUOTE]
Hi Ivar,
27.09.2012, 11:17 GMT-4
I cannot really say which is best, as what you are doing is not something I have done so far (prev() operators),
To date, I have always managed with only the old "3.5 way" that works also in v4 ;)
28.09.2012, 08:21 GMT-4
An update to my solution: I found in the documentation that you can use the variable "timestep" which holds the value of the current timestep the solver is taking.
So to find my delta Temperature, I multiplied the slope of Temperature at the current timestep, Tt, by the variable "timestep" which should provide a delta value.
