10.09.2012, 07:57 GMT-4
it depends on your geoemtry overall dimensions, if averything is small 1e-9 nm, apart settign the absolute tolerance to < 1e-9 I do not see what you need to tweak.
The difficulty is when you compare a 1mm^3 obhect and you add a small part about 1nm^3 inside, then the ratio of size > 1:10'000 or slightly more qill give you some issues, I never have tw object in direct contact with size ration above 1:10'000, I then add some local internal boundaries around the small parts to respect my size ratio. Then i manually mesh these small parts first and increase the mesh per layer until I com eto the "mocro parts.
This mostly runs nicely and smoothely, but it oes not work in 1click automatic ;)
11.09.2012, 04:50 GMT-4
When I use "User controlled" mesh and scale the z-axis with 1e4 the meshing goes fine. But I get extremely dense meshing in the z axis whish is the opposite of what I want. But when I set x and y to 1e4 I get
"Mesh warning (ftet1): Failure due to incomplete boundary mesh."
Best
Martin
Best
Martin
11.09.2012, 14:54 GMT-4
depending on what you are doing, then a regular mesh (square or "high" mesh "quality") might not be the optimum, sometimes it is imporat to have several mesh elements in the "thin" thickness direction butthe mesh elements might have a large extent in the perpendicular direction (very model and dependent variable gradient field dependent, be aware) so your mes does not necessarily need to be "regular", with ths elements, I mostly mesh the surface, and thn sweep it through the thickness with a few elements depending on my expected results. Or I mesh the short edges, before the full domain
Meshing is somewhat an "art" but with some sensible scientific touch, from the preknowledge of expected results
12.09.2012, 03:43 GMT-4
I just want to mesh a cylinder with a high 1e-10m and radius 1e-6 m . Then I want to fix the radial boundary and apply a body force along the z-axis.
I don't understand how I can mesh first the radial border and then sweep this inward in the radial direction? I can't do this with "Build all", right? I think it should be just fine with very few elements in z and some powers more in the radial direction?
Best
Martin
Best
Martin
19.09.2012, 01:58 GMT-4
with such differences in shape, you should add a few intermediate boundaries to allow the mesher to mesh region by region (domain ba domain) with at most 1:1000 to 1:10'000 size ratio
Ruud Borger
COMSOL Employee
19.09.2012, 11:20 GMT-4
Hi Martin,
As Ivar says, a Swept mesh would be best suited for these type of geometries. You can set it up as follows:
-Mesh the upper surface area, with a free triangular or free quad. If desired, right click and add a Size to specify the size.
-Next, add a Swept mesh. By right clicking this, you can determine how many layers you want through the thickness.
Attached is an example.
Ruud Börger
COMSOL
Hi Martin,
Ruud Börger
COMSOL
25.03.2014, 00:14 GMT-4
hi
I am struck in meshing, i have 3 layers, the last two are same. i mesh the surface of first layer and then swept it down. I select second domain but it is not sweping through it. please let me know if there any example of swept meshing for multi layers.
hi
