Criteria for Extracting a 2D Slice Data from a 3D model
What is COMSOL's criteria when I extract slice data from a 3D gridded model? Is it simply finding the nearest node points? If so, is it only including node points immediately adjacent to the slice plane, or is there a tolerance where a node point has to be within a certain distance of the slice plane?
1 Reply Last Post 29.08.2012, 21:01 GMT-4
Posted: 1 decade ago 29.08.2012, 21:01 GMT-4
check the node settings, it uses interpolation from closest elements, you can play with eome of theparameters such as polynomial order etc, check the doc
Hi check the node settings, it uses interpolation from closest elements, you can play with eome of theparameters such as polynomial order etc, check the doc -- Good luck Ivar
