Hello Patrice Gouin
11.10.2012, 03:29 GMT-4
I am also doing Induction hetaing in §d work space, m also geting a same error.
Could you able to find any solution? please let me know know.
Thank you
Thank you
Andrea Ferrario
COMSOL Employee
11.10.2012, 08:08 GMT-4
Patrice, Chirag,
are you using version 4.0a? Please try with a more recent version and the error should disappear.
Andrea Ferrario
Electromagnetics Group
COMSOL AB
Patrice, Chirag,
Andrea Ferrario
COMSOL AB
11.10.2012, 08:48 GMT-4
hi all,
Now I'm using Comsol 4.2.
Instead of having an error, the model just don't give any answer, but when I added fillet to my sharp edge it works. Unfortunately, the simulation don't give the same results I obtained experimentally.
Is someone knows if we have to put an initial current higher which will stabilize by itself?
Pat G.
hi all,
Pat G.
11.10.2012, 10:21 GMT-4
do not forget that sharp edges are singularities in many physics, as you do not know how to define a x-y-z spatial derivative on such a vertex
Also v4.0 was the first one out not really ironed out either, I strongly suggest to rebuild your model fully in a newer version (not jsut load in and "translate" this applies particularly for the pre 4.1, as backward compatibility is far better for the latest versions
11.10.2012, 13:37 GMT-4
Hi all,
I'm trying to upload my model in this forum but it's too big. Does someone know how to save it without the solution?
Thank you
Pat G.
Hi all,
Thank you
Pat G.
11.10.2012, 15:48 GMT-4
indeed yes, check the forum more regularly, or try a search ... Or even read the doc ;)
But if you go to (depends on version) edit clear all solutions edit claer all mesh then File reset history you should strongly reduce the model size. Anyhow one should always do this before uploading a model (at least in V4) as lse we will overload the forum disk with not very useful data. (do not DELETE, just clear
Some issues: in older v3.5a you loose your mesh, and the meshing history is NOT stored so perhaps try to NOT clear the mesh for v3.5a
for complex conditional and copled sovler sequences, these might reset their initial pointer settings in v4.3.
Workaround, once cleared all solutions, generate the initial conditions of the first "master(s)* solving sequences, from which the unsolved variables are loaded from, then check the logic of the initial conditions of all solvers, then delete the mesh and save. (this workaround only concerns complex linked solver sequences, and probably will behave better & easier from next patch, at least that is what I understood from "support" on my inquiry). Anyho I strongly suggest that you get a more mature version than 4.0.
12.10.2012, 03:29 GMT-4
Hello Patrice,
I am using latest version of comsol, and the error was like following:
Failed to find a solution for the initial parameter.
Divergence of the linear iterations.
Please guide me if anyone having an idea about it.
It would be greatful if you upload your model.
Thanks a lot.,
Chirag Oza
Hello Patrice,
Thanks a lot.,
Chirag Oza
