NdFeB or other permanent magnet material
Hi all,
I can not find any permanent magnet material in Material library ?
3 Replies Last Post 17.07.2012, 01:30 GMT-4
Posted: 1 decade ago 16.07.2012, 14:34 GMT-4
I mostly define an "Amper laws physics" node(s) for my magnet(s) with a magnetisation value of about the Hc value. This seems so far to give decent results for high quality linear rare earth type magnets, and not too close to the Curie temperature
Hi I mostly define an "Amper laws physics" node(s) for my magnet(s) with a magnetisation value of about the Hc value. This seems so far to give decent results for high quality linear rare earth type magnets, and not too close to the Curie temperature -- Good luck Ivar
Posted: 1 decade ago 16.07.2012, 17:23 GMT-4
Thank you for the answer. Yes we can define magnet as your answer.
But, there are many types of permanent magnets with different permeability, conductivity, temperature, etc...
And, I want to define permanent magnet as material with the name of the matrial as NdFeBr and samarium cobalt, etc..
Is it possible to customise the permanent magnet materials with cited above parameters and others
Kamel Boughrara
Thank you for the answer. Yes we can define magnet as your answer. But, there are many types of permanent magnets with different permeability, conductivity, temperature, etc... And, I want to define permanent magnet as material with the name of the matrial as NdFeBr and samarium cobalt, etc.. Is it possible to customise the permanent magnet materials with cited above parameters and others Thanks Kamel Boughrara
Posted: 1 decade ago 17.07.2012, 01:30 GMT-4
I believe so, but I must admit I have never tried.
You can define a saturated iron (see the material DB) then you should also be able to define a Temperature and field dependent magnetisation
It would be nice indeed to have more examples of hysteresis curve type material properties in COMSOL, so if you progress in this field, pls publish it here too, as I'm sure that is of interest for many of us out here ;)
Hi I believe so, but I must admit I have never tried. You can define a saturated iron (see the material DB) then you should also be able to define a Temperature and field dependent magnetisation It would be nice indeed to have more examples of hysteresis curve type material properties in COMSOL, so if you progress in this field, pls publish it here too, as I'm sure that is of interest for many of us out here ;) -- Good luck Ivar
