10.07.2012, 03:27 GMT-4
try to avoid thinking mesh and nodes for postprocessing in COMSOL, you will get confused, that is the "old" way of FEM. COMSOl uses entities: geoemtric domains, boundaries (and perhaps edges and points if applicable). You shoudl use the properties on domain and boundaries (volumes and surfaces in 3D, surfaces and edges respectively in 2D) and select the boundaries and plot thereafter. COSMOL will then apply the values to these entities. Not that a Boundary heritates its results from the surrounding domains, which means that sometimes you get average values, or undefined derivatives as these cannot be correctly estimated, all depends on your model set up
10.07.2012, 04:09 GMT-4
Thank you for your response.
Actually I need a coordinate of an area on the surface which I do not have access through the geometry information. but if I have the value of the nodes on that area and their coordinates, I would find coordinate of that area which I could but it takes too long as it solves the problem again over the nodes.
I just wanted to know whether I can have it without solving the problem again.
Hoda
Hoda
