03.07.2012, 09:27 GMT-4
if you include the total force of source and destination = magnet and iattracted ron you should get a net "0" or thereabout. What about trying to solve for two forces, one for each shpere and compare the two (with opposed signes)
03.07.2012, 09:46 GMT-4
Thank you for your reply.
I don't get any result, I get the error message that the variable dnphi cannot be evaluated at the boundaries of the sphere no matter which sphere I choose.
The thing worked in 3 d, but I wanted to save computing force, so I did it in 2d axisymmetric.
The name of the variable (dnphi) shows also that I have probably done something wrong with the 2d axisymmtric geometry.
04.07.2012, 03:04 GMT-4
it did solve OK for me but I have v4.3, when I split the force (with different 2 names) into two.
But, I noticed that the error(differences) was quite large, I didnt have time to check out why. Back in 4.2 sometimes I got more preciese results with MF rather than MFNC, even if I had no curent. And from v3.5 I know that force estimation is very mesh density and mesh shape dependent
04.07.2012, 07:17 GMT-4
Thank you, it worked when I took MF.
04.07.2012, 07:39 GMT-4
Interesting, I wounder what is so different between MF and MFNC, in case you find out pls report back
