Electrical Circuit (cir) interface and Time Dependent Study
I am working with a 3D model in Comsol 4.2a. I can successfully run the eigen study, frequency domain study and time dependent study.
But when I introduce the Electrical Circuit interface instead of directly applying boundary conditions to the model itself, I dont get the same results with my Time Dependent study as I get without the circuit interface. In fact, the plots for potential and displacement are all zeroes.
Is there a parameter I am missing out on with respect to using the Electrical Circuit interface? Or could there be some other issue? Any ideas?
Thank you.
Sneha
1 Reply Last Post 22.06.2012, 05:15 GMT-4
Posted: 1 decade ago 22.06.2012, 05:15 GMT-4
probably you have not managed to couple the two physics, CIR can only couple to a large model via terminals and the appropriate UI or IU links, check it out on the Model library examples
Hi probably you have not managed to couple the two physics, CIR can only couple to a large model via terminals and the appropriate UI or IU links, check it out on the Model library examples -- Good luck Ivar
