How to generate flux in Permanent magnet after assigning N52 grade Ndfeb magnet
What are the steps i follow to do simulation.
1 Reply Last Post 29.06.2021, 03:25 GMT-4
Posted: 4 years ago 29.06.2021, 03:25 GMT-4
The attached model should get you started. I have pretty much used the default settings, but have added an Infinite Element domain on the model exterior to better simulate far field at the model boundary.
Perhaps the key step is to add a "Magnetic Flux Conservation" node in your MFNC physics.
The attached model should get you started. I have pretty much used the default settings, but have added an Infinite Element domain on the model exterior to better simulate far field at the model boundary. Perhaps the key step is to add a "Magnetic Flux Conservation" node in your MFNC physics.
