[SOLVED] Times to store: "Steps taken by solver" causes ERROR
Posted 10.05.2012, 01:11 GMT-4 Studies & Solvers Version 4.2, Version 4.2a 1 Reply
I have a model, which runs fine. If I make a single change — switch Times to store from "Specified values" to "Steps taken by solver" — the model no longer converges. I get the following error:
Nonlinear solver did not converge.
Singular matrix.
There are 101 equations giving NaN/Inf in the matrix rows for the variable mod1.Ve.
at coordinates: (0), (1e-008), (2e-008), (3e-008), (4e-008), ...
There are 100 equations giving NaN/Inf in the matrix rows for the variable mod1.Vi.
at coordinates: (1e-006), (1.01e-006), (1.02e-006), (1.03e-006), (1.04e-006), ...
There are 1 equations giving NaN/Inf in the matrix rows for the variable mod1.h.
at coordinates: (1e-006), ...
There are 1 equations giving NaN/Inf in the matrix rows for the variable mod1.m.
There are 1 equations giving NaN/Inf in the matrix rows for the variable mod1.n.
and similarly for the degrees of freedom, NaN/Inf in the matrix columns.
Time : 0.0002
The end of the detailed log output says:
Step Time Stepsize Res Jac Sol Order Tfail NLfail
4864 0.0001997 1e-007 out 9820 70 9820 2 5 0
Iter Damping Stepsize #Res #Jac #Sol
1 1.0000000 2.9e-008 9821 70 9821
2 1.0000000 5.1e-009 9822 70 9822
4865 0.0001998 1e-007 out 9822 70 9822 2 5 0
1 1.0000000 2.9e-008 9823 70 9823
2 1.0000000 5.1e-009 9824 70 9824
4866 0.0001999 1e-007 out 9824 70 9824 2 5 0
1 1.0000000 3e-008 9825 70 9825
2 1.0000000 5.1e-009 9826 70 9826
4867 0.0002 1e-007 out 9826 70 9826 2 5 0
4867 0.0002 0 out 9837 81 9826 2 5 10
Time-Dependent Solver 1 in Solver 1: Solution time: 49 s.
In particular, Stepsize is zero. But is it really a different step? If the step number is the same as the previous step?
I thought that Times to store shouldn't affect the solution process. All it should do is choose at which points to output the solution. I'd like to use "Steps taken by solver" so that I can resolve certain features in the output, which coincide with the solver taking smaller step sizes.
Singular matrix.
Time : 0.0002
1 Reply Last Post 10.05.2012, 01:43 GMT-4
