Is the "node" in circuit the same with the "boundary" in lumped ports?
Hi everybody.
I'm new here and i have come across with many many stupid questions like this== .
If they are different ,then what does the "node" refers to when I want to add a voltage excitation in the physics "circuit" into the model.
Thank you very much.
3 Replies Last Post 07.05.2012, 14:18 GMT-4
Posted: 1 decade ago 04.05.2012, 11:12 GMT-4
the node in the Circuit are the Spice type nodes (where you sum the currents) while in the BC itsTerminal id numbers to distinguish the different terminal names
Hi the node in the Circuit are the Spice type nodes (where you sum the currents) while in the BC itsTerminal id numbers to distinguish the different terminal names -- Good luck Ivar
Posted: 1 decade ago 07.05.2012, 08:19 GMT-4
Thank you Ivar!
Now I want to add a voltage source between two terminals , how can I define the "node" in the setting window of the voltage source?
Should I define the nodes first? Where should I do this then?
Thank you so much,
sincerely yours.
Thank you Ivar! Now I want to add a voltage source between two terminals , how can I define the "node" in the setting window of the voltage source? Should I define the nodes first? Where should I do this then? Thank you so much, sincerely yours.
Posted: 1 decade ago 07.05.2012, 14:18 GMT-4
you can define a boundary to gnd and another to a voltage source inside most ACDC physics without any "circuit".
The latter is really usefull if you want to add some know electronics, such as an amplifier or a feedback loop or a sensor conditionner electronics with a know impedance
Hi you can define a boundary to gnd and another to a voltage source inside most ACDC physics without any "circuit". The latter is really usefull if you want to add some know electronics, such as an amplifier or a feedback loop or a sensor conditionner electronics with a know impedance -- Good luck Ivar
