Extrude/giving thickness to a parametric curve
I am using a parametric curve to describe a geometry and I would like to give it a thickness (on the z-axis) to it. How can I extrude this correctly? Both extrude and sweep don't seem to work in this case. Any suggestions?
2 Replies Last Post 18.01.2021, 06:16 GMT-5
Posted: 4 years ago 18.01.2021, 05:48 GMT-5
Guilherme,
you should be able to extrude the curve when you define it on a workplane.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Guilherme, you should be able to extrude the curve when you define it on a workplane. Cheers Edgar
Posted: 4 years ago 18.01.2021, 06:16 GMT-5
Updated: 4 years ago 18.01.2021, 11:10 GMT-5
Dear Edgar,
In my file, when I try to create a working plane, the 2-D representation of it includes all the other geometries drawn while I want to extrude the "square" I've created with the parametric curve. May I ask how I set the workplane to include only the parametric curve I've created?
EDIT: After a long while I understood that I had to insert the parametric curve inside the work plane in COMSOL. However now I need to fill this parametric curve (I want it to be a solid). Can I ask to directions again?
Dear Edgar, In my file, when I try to create a working plane, the 2-D representation of it includes all the other geometries [drawn](https://imgur.com/a/q7I6MU6) while I want to extrude the "square" I've created with the parametric curve. May I ask how I set the workplane to include only the parametric curve I've created? EDIT: After a long while I understood that I had to insert the parametric curve inside the work plane in COMSOL. However now I need to fill this parametric curve (I want it to be a solid). Can I ask to directions again?
