How to assemble different solutions into one plot?
Good evening Comsol community.
Can you please help me?I AM VERY NEWBIE. Is it possible to assemble several solutions into one and plot them?
In my problem I need to do a parametric frequency sweep. So I did it as follows:
*I run my model once with a frequency of 100hz with time ( 0, 0.001, 2). *Then I run the model again with a 120HZ with time (0, 0.001, 2) *Then I run the model again with a 140Hz with time (0, 0.001, 2)
HERE is the problem, I need to assemble the 140Hz with the 120Hz with the 100 Hz solutions and then show the results into one plot.The correct way is running the model at 100Hz from 0 to 2 secs, then assemble that solution with the next, from 2 to 4 secs with 120Hz, then assemble that solution with the next, from 4 to 6 secs with 140Hz.
Can you give me some thoughts please? Any suggestions?
I am working on this through Matlab and I found this in the documentation:
SET LINEARIZATION POINTS mphstate uses linearization points to assemble the state-space matrices. It may help me?
Thanks in advance.
0 Replies Last Post 06.01.2021, 02:08 GMT-5
Hello Victor Navarrete
