SUPG stabilisation for general PDE
Hello
Myself and some colleagues have been developing an elastohydrodynamic contact model.
We have used the weak form of the general PDE (the PDE we solve is called the Reynolds' equation) and the expression for the deformed oil film thickness has been calculated using an integration coupling constant. We also use an integration coupling constant to calculate the integral of the pressure over the contact, and solve for this integrated pressure being equal to the applied load.
It all works OK, but at high loads, there are oscillations in the pressure curve, which need stabilising out. We have tried adding some isotropic diffusion but I would really like to add SUPG stabilisation.
I notice that these can be implemented using the GUI for fluid flow models - has anyone had any success implementing SUPG using the general PDE's ?
Thanks for any help
1 Reply Last Post 19.09.2010, 13:00 GMT-4
Hello Robert Taylor
Posted: 1 decade ago 19.09.2010, 13:00 GMT-4
Dear Robert,
I must admit I have EXACTLY the same problem of EHL (right now only 1D for me). And try to solve in the same way I guess. It works fine until high loads as you told... Have you succeeded in implementing any stabilization technique on the PDE module since this time?
Dear Robert, I must admit I have EXACTLY the same problem of EHL (right now only 1D for me). And try to solve in the same way I guess. It works fine until high loads as you told... Have you succeeded in implementing any stabilization technique on the PDE module since this time?
