4 years ago
05.01.2021, 21:48 GMT-5
Hi Wen Jiang,
It's better you attach your model file here in order for me to suggest apropreate answer to your question.
Rahul Shah.
Hi Wen Jiang,
Rahul Shah.
Jeff Hiller
COMSOL Employee
4 years ago
06.01.2021, 08:35 GMT-5
Updated:
4 years ago
06.01.2021, 09:14 GMT-5
Wen,
You say that the displacements are ridiculously large and don't change with the parameters. Are you saying that based on the way the displacements are rendered on screen, or based on the values on the colorbar? By default, deformations are displayed scaled in such a way that they are easily visible with the naked eye. Their actual magnitude can be read off the colorbar. You can also change the scaling factor manually to 1 if you do not want any scaling, but then you won't be able to really see them.
Jeff Hiller
Wen,
4 years ago
13.01.2021, 15:07 GMT-5
Wen,
Hi Jeff,
Thanks for replying, I took 1D plots on the cross-sections on two different directions (x and y), and reading from the plots the displacements were above 7500mm on the edges and never change however I change the parameters. The only change happens when I change the CTE to negative, that the displacements become negative.
Wen
>Wen,
>Best regards,
>Jeff
Hi Jeff,
Wen
Jeff Hiller
COMSOL Employee
4 years ago
13.01.2021, 15:25 GMT-5
Updated:
4 years ago
13.01.2021, 16:11 GMT-5
You are saying that you are reading the displacements "from the plots" but that does not answer my question of whether you are eyeballing the displacements magnitude from the general look of their graphic rendition or whether you are reading their values displayed next to the colorbar while plotting the norm of those displacements. If it is the latter, please post your .mph file and I'll take a look at it.
Jeff Hiller
