Nagi Elabbasi
Facebook Reality Labs
31.03.2012, 13:49 GMT-4
Yes it is possible. Functionally Graded Materials have a material composition that changes gradually with volume. You can do that in COMSOL by specifying the material properties, such as Young’s modulus, to be a function of the spatial coordinates.
Nagi Elabbasi
Veryst Engineering
Nagi Elabbasi
Veryst Engineering
17.04.2012, 07:10 GMT-4
Dear All,
I want to know how to model FGM in COMSOL 4.2.
Please help me in this case because I am new in COMSOL.
Regards.
Dear All,
Regards.
19.02.2014, 07:06 GMT-5
Dear All,
Regards.
Hi, i want to know how modelling young modulus as a function in one dimension for example ,,z" based on FGM material?
[QUOTE]
Dear All,
Regards.
[/QUOTE]
Nagi Elabbasi
19.02.2014, 08:41 GMT-5
In the material definition instead of specifying Young’s modulus as a constant make it a function of Z, for example 100+10*Z
02.03.2014, 00:26 GMT-5
I am new to comsol. I want to solve a problem of functionally graded piezoelectric material (FGPM) with sigmoid law. I want the variation of properties should be continuous within a geometry, i do not want variation in layers means problem is converted into several layers. Each layer has a constant properties but they are different from another layer and the difference is maintained by variation of properties by sigmoid law, than layers glue together and then solve, I do not want this which was happened in other FE softwares. Does comsol solve the problem in which properties vary continuously in a geometry, i do not want a stepwise variation?
31.03.2014, 09:03 GMT-4
Hi. thank you for answer, but how am i defining variable Z which are my thickness of beam in boundary Z belong to [-0.5;0.5]?
K. Żur
K. Żur
31.03.2014, 09:05 GMT-4
And when i have 3D problem and young moduli is variable in one dimension?
K. Żur
K. Żur
02.04.2014, 06:45 GMT-4
Please help me defining variable z (thickness of beam belong (-0.5, 0.5)) and z is variable material properties along the thickness E(z)= (z+0.5)^n
K. Żur
K. Żur
