Creating a variable charge on a surface
I'm currently attempting to model the electrospray deposition process using a combination of matlab and comsol (in 2D axissymmetric). The matlab code I'm using takes the model and solves for a particle trace from the field. Using the particle trace, it determines where each droplet and charge would be deposited on the spray target (a rectangle), creating a table of radial values and charge values at these points. Using these new charge values, I want to be able to update the electric potential or charge on the surface of the spray target in the comsol model, but not as a single value as it will easily allow one to do, but update the charge at specific points as the charge is deposited. I've tried doing this but it only allows a single scalar value to be used to update electric potential. Is there a way to do this without creating dozens of individual point charges and updating those individually? Can an array basically be fed into the electric potential or perhaps a different electrostatics tool to do this? Thanks!
1 Reply Last Post 23.06.2020, 15:11 GMT-4
Posted: 4 years ago 23.06.2020, 15:11 GMT-4
Catherine,
the scalars in the input fields for potentials or charge densities can be functions of the spatial coordinates, e.g. Vs = Vs(r, z). This is the way to introduce a spatial distribution.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Catherine, the scalars in the input fields for potentials or charge densities can be functions of the spatial coordinates, e.g. Vs = Vs(r, z). This is the way to introduce a spatial distribution. Cheers Edgar
