Rotational Friction
Hi everybody, I have checked out your blogs but I have not been able to find how to do a 3D simulation that get  the heat from the friction between two boundaries with only relative rotational speed. I want to use the node "contact" but I am not sure if a rotational movement is supported.
2 Replies Last Post 16.08.2020, 23:17 GMT-4
Hello Luis Gonzalez
Posted: 4 years ago 28.07.2020, 04:36 GMT-4
Hello Luis Gonzalez
I also want to build a frictional heat model, but I have encountered the same problem as you. How did you solve it?
Thank you
Hello Luis Gonzalez I also want to build a frictional heat model, but I have encountered the same problem as you. How did you solve it? Thank you
Posted: 4 years ago 16.08.2020, 23:17 GMT-4
Hello Luis Gonzalez
Thank you
At the moment, I have suppossed the thermal behavior as a function of the radius and the thermal contact pressure. Then, I am working on the mecanical phenomenom.
>Hello Luis Gonzalez > >I also want to build a frictional heat model, but I have encountered the same problem as you. How did you solve it? > >Thank you At the moment, I have suppossed the thermal behavior as a function of the radius and the thermal contact pressure. Then, I am working on the mecanical phenomenom.
