Time-dependent problem-convergence issues
I am working on a time-dependent FSI problem. The problem converges well when I model the solid as a linear elastic material. However I end up with convergence issues and inverted mesh elements when I use a hyperelastic material model to represent the solid.
I am wondering if someone can explain why this is happening and how do I fix this?
Sirisha
1 Reply Last Post 09.02.2012, 18:24 GMT-5
Posted: 1 decade ago 09.02.2012, 18:24 GMT-5
I tried running the problem with the solid modeled as a linear elastic material and I also selected the geometric non-linearity option. I am getting inverted mesh elements even in this case.
I am wondering if someone can suggest some basic reasons as to why this is happening only when the hyperelastic material is used (or when the non-linearity option is selected).
Thanks for the help.
Sirisha
I tried running the problem with the solid modeled as a linear elastic material and I also selected the geometric non-linearity option. I am getting inverted mesh elements even in this case. I am wondering if someone can suggest some basic reasons as to why this is happening only when the hyperelastic material is used (or when the non-linearity option is selected). Thanks for the help. Sirisha
