materials of a surface mesh element
Hi everyone ,
I’m looking for a possibility to distinguish the different materials that belong to a single surface-mash-element (for example: a triangle) in matlab? For better understanding - my problem in a second way. Starting from a model containing a single meshed surface. Each mesh-element is now between two materials. So how do I get knowledge about the two materials/groups/… the element is between?
Thanks for help!
3 Replies Last Post 10.04.2013, 05:11 GMT-4
Posted: 1 decade ago 07.02.2012, 03:04 GMT-5
None of you have any idea?
Posted: 1 decade ago 08.02.2012, 17:34 GMT-5
I'm not sure I undertand you, in COMSOL, materials are defined on the "Entities" (domains, boundaries) and the mesh gets, when required, info by "heritance". If you select the material nodes you see which entity is of which material.
Else you could perhaps plot a surface in "wireframe" mode without smoothing (raw mesh mode) and ask for a material property, such as "rho" or "mur" then the color code will give you indictions which region is what, but still its shows the "Entities" with the superposed mesh
Hi I'm not sure I undertand you, in COMSOL, materials are defined on the "Entities" (domains, boundaries) and the mesh gets, when required, info by "heritance". If you select the material nodes you see which entity is of which material. Else you could perhaps plot a surface in "wireframe" mode without smoothing (raw mesh mode) and ask for a material property, such as "rho" or "mur" then the color code will give you indictions which region is what, but still its shows the "Entities" with the superposed mesh -- Good luck Ivar
Posted: 1 decade ago 10.04.2013, 05:11 GMT-4
The information can be extracted via matlab by:
mphxmeshinfo(model)
within the element section
The information can be extracted via matlab by: mphxmeshinfo(model) within the element section
