Thermal expansion mass balance.
Posted 30.03.2020, 19:07 GMT-4 Computational Fluid Dynamics (CFD), Heat Transfer, Structural Mechanics Version 5.5 0 Replies
I am working on model which involves phase change. I can model that successfully, but I noticed mass is varying as the temperature varies. (makes sense as volume is constant but density varies with T)
I tried coupling with thermal expansion Multiphysics, but still mass is varying.
In both the cases, I used volume average to find the mass of the domain. I also tried defining intop function and defined mass variable. Still the same.
I also checked comsol tutorials, I noticed the same issue.
How to build a model without mass change?
Thank you
Hello Bharanidharan Rajasekaran
