plotting only part of mesh in Comsol 4.x (like meshplot with ellog in Comsol 3.5a)
in Comsol 3.5a it was possible to plot only a part of a mesh by using meshplot and defining constraints with 'ellog'. Is there an equivalent feature included in Comsol 4.x for mphmesh or another way of getting this done?
Thank you in advance
2 Replies Last Post 09.01.2012, 15:47 MEZ
Posted: 1 decade ago 09.01.2012, 14:24 MEZ
In V4, try to add a Plot "Filter" (right click the plot sub-node) with "x>0" or some other Boolean expression.
Or make a sub-Data set via an appropriate cut plane, line ...
Hi In V4, try to add a Plot "Filter" (right click the plot sub-node) with "x>0" or some other Boolean expression. Or make a sub-Data set via an appropriate cut plane, line ... -- Good luck Ivar
Posted: 1 decade ago 09.01.2012, 15:47 MEZ
Thank you Ivar - this works for me perfectly :)
