Solving for power using surface integral of E^2
Im trying to calculate the power desipated in the silicon layer. So Im using surface integral in derived values, as power is intergral of E^2.
I changed the expression from 'Electric field norm' i.e emw.normE to emw.normE^2, does this approach give the correct values of power ?
And other case is Ive changed the expression to 'Total power dissipation density' that is the module itself, It has the units 'W/m'.
The latter sounded good for me, But want to check in before hand.
Please clarify me.
1 Reply Last Post 06.02.2012, 21:49 GMT-5
Posted: 1 decade ago 06.02.2012, 21:49 GMT-5
I'm not sure what dimension problem you are working in. Regardless, power dissipation is not simply E^2. Integrating "Total power dissipation density" over the volume, area, or edge in question (depending on the dimension of your problem) sounds like a better choice to me.
