charged particle deposition
Hi all,
i'm trying to model (3D) an electrodeposition of nanoparticles under laminar conditions (fluid flow), but i've no idea....which module i should use. I'm using the comsol version 4.2a.
any idea to help me out, will be very thankful
kamdem
1 Reply Last Post 16.04.2013, 13:08 GMT-4
Hello Kamdem Nounamo
Posted: 1 decade ago 16.04.2013, 13:08 GMT-4
Did you ever find anything out about this? I am currently looking at using charged particle tracing where the charged particles are in a laminar flow under the influence of an oscillating magnetic field... So, i understand your problem. My particles will either see the fluid flow or the magnetics, but struggle to see both effects. Thanks in advance if you've found anything new.
