Simulate pressure (fluid) through a pipe
Hi, I am a Student and don't have much experience with COMSOL.
I want to simulate the pressure and stress on a pipe (like a very tiny syringe needle). The pipe itself is very thin and the material has to be gold. The fluid (Propanol - laminar) comes with high pressure and has got a diffrent temperature than the pipe.
I tried some tutorials, but haven't found any information about the effect the fluid-flow has on the pipe. I hope someone can give me an idea how getting started.
Best regards Eddy
3 Replies Last Post 04.11.2019, 03:47 GMT-5
Hinrich Arnoldt COMSOL Employee
Posted: 5 years ago 30.10.2019, 09:49 GMT-4
Hello Eddy,
if you want to compute the pipe's mechanical stress you will need to include fluid-structure coupling. See e.g. https://www.comsol.de/blogs/simulating-fluid-structure-interaction-in-a-ball-check-valve/ and the links therein.
If you want to study the resulting heat distribution you will need to couple the flow with a heat transfer interface. See e.g. https://www.comsol.de/blogs/finding-the-ideal-thickness-for-the-insulation-of-a-pipeline/
Kind regards Hinrich Arnoldt
Hello Eddy, if you want to compute the pipe's mechanical stress you will need to include fluid-structure coupling. See e.g. https://www.comsol.de/blogs/simulating-fluid-structure-interaction-in-a-ball-check-valve/ and the links therein. If you want to study the resulting heat distribution you will need to couple the flow with a heat transfer interface. See e.g. https://www.comsol.de/blogs/finding-the-ideal-thickness-for-the-insulation-of-a-pipeline/ Kind regards Hinrich Arnoldt
Posted: 5 years ago 30.10.2019, 10:17 GMT-4
Updated: 5 years ago 30.10.2019, 06:17 GMT-4
If you are interested in Fluid Structure Interaction modeling with COMSOL, an additional resource is this video.
Jeff Hiller
If you are interested in Fluid Structure Interaction modeling with COMSOL, an additional resource is [this video](https://www.comsol.com/video/modeling-fluid-structure-interaction-with-comsol-multiphysics). Best regards, Jeff
Posted: 5 years ago 04.11.2019, 03:47 GMT-5
Hello Eddy,
Thank you very much! Helped a lot!
>Hello Eddy, > >if you want to compute the pipe's mechanical stress you will need to include fluid-structure coupling. See e.g. https://www.comsol.de/blogs/simulating-fluid-structure-interaction-in-a-ball-check-valve/ and the links therein. > >If you want to study the resulting heat distribution you will need to couple the flow with a heat transfer interface. See e.g. https://www.comsol.de/blogs/finding-the-ideal-thickness-for-the-insulation-of-a-pipeline/ > >Kind regards >Hinrich Arnoldt Thank you very much! Helped a lot!
