01.11.2011, 23:56 GMT-4
I think you will have to use the weak form.
You can look at the weak forms of the equations in a species transport problem, the equations are similar. You will have a good idea of how to develop you're equation.
02.11.2011, 11:08 GMT-4
I don't really use general form modelling it should look like
∂u1/∂t + ∇• Γ = f'
with Γ = D∇u1 and f' = f - ∇• D∇u2 as long as there is not some sort of functional dependency of type u2[u1]. Also, weak form modelling can be easily applied to this equation and may offer some advantages if you are interested in moving domains. Weak form (for Neumann boundary conditions) looks like
∫(ψ ∂u1/∂t) dx - ∫(∇ψ • ∇u1) dx = ∫ψf' dx
Hope this helps,
Alex
∂u1/∂t + ∇• Γ = f'
Hope this helps,
Alex
02.11.2011, 14:20 GMT-4
Thanks for your response...I will try with the weak form...
02.11.2011, 15:49 GMT-4
Thanks for your reply. I am trying to represent my system of equations in the general/coefficient form first. How do I represent ∇u1 or ∇^2 u1 in COMSOL either in the conservative flux or the source term?
02.11.2011, 19:52 GMT-4
Differential operations are represented by
∂u1/∂x → diff(u1,x) or simply u1x
which works for all coordinates as well as time. The first expression is the actual formulation, by default COMSOL defines the second one as the first for but only for variables within the model, so it will not work for any self defined functions. Scalar products need to be written as sums of these expressions.
Depending on u2, higher order operators can be a little bit tricky. If you have an analytic form of u2, you should be fine, however, if u2 is a solution of an FEM-simulation you may notice that the operation
∂²u2/∂x² → diff(diff(u2,x),x)
is 0 everywhere which is a consequence from the underlying H1-discretization. If that should be the case, it usually helps to define an additional application mode and set u3 via something like u2x = u3 and employ
∂²u2/∂x² = ∂u3/∂x→ diff(u3,x)
in the original set of equations. However, I am still working with COMSOL 3.5, so it is possible that there have been some changes in the syntax. Just try it, otherwise, you will have to check the doku.
Alex
Alex
08.11.2011, 17:24 GMT-5
Thanks Alex. In version 4.1 i figured out the 2nd derivative is represented as u1xx.
