Sin wave signal Input in Laminar Flow
Hey All,
I am trying to simulate Laminar flow in a Channel where the inlet velocity is being updated by a Sin-wave function and I have some queries in this regard.
1. Does COMSOL has an option for 'offset' of fuctions ? or I just have to give it manually in my velocity inlet field of the Physics .
2. A Sin-wave should result in a reverse flow in the channel (since it occurs between +z and -z , where 'z' represents the upper and lower limits of amplitude) but unfortunately , I am unable to see the phenomenon in my simulation.
Please have a look at the attached model and give me some suggestions.
Thank you for your help in advance .
Sincerely,
Irfan Malik
2 Replies Last Post 21.10.2011, 04:45 GMT-4
Lechoslaw Krolikowski
Posted: 1 decade ago 17.10.2011, 12:38 GMT-4
Note the period of the function wv1 !
If you want to see the velocity and pressure pulsation then extend your simulation to, say 6s.
Andrzej
Hi, Note the period of the function wv1 ! If you want to see the velocity and pressure pulsation then extend your simulation to, say 6s. Regards, Andrzej
Posted: 1 decade ago 21.10.2011, 04:45 GMT-4
Andrzej
Thanks a lot Andrzej :) That worked .
If I am getting it right, this is because the sin wave has a frequency of 2*pi . so pulsations were not being observed before this time
[QUOTE] Hi, Note the period of the function wv1 ! If you want to see the velocity and pressure pulsation then extend your simulation to, say 6s. Regards, Andrzej [/QUOTE] Thanks a lot Andrzej :) That worked . If I am getting it right, this is because the sin wave has a frequency of 2*pi . so pulsations were not being observed before this time
