5 years ago
17.02.2019, 18:37 GMT-5
1) In the geometry, make the solid and beam touch
2) In the physics menu, add multipysics
3) right click on the multiphyics node and add "Solid Beam Connection"
4) make a fine mesh around the connection
I found that I had to remake the Solid Beam Connection if the topology changes. I also found it tricky to get solver convergence in some circumstances
Henrik Sönnerlind
COMSOL Employee
5 years ago
18.02.2019, 05:12 GMT-5
Updated:
5 years ago
If you are using the beams as reinforcement bars inside the concrete, the best method is to do exactly as in
https://www.comsol.com/model/concrete-beam-with-reinforcement-bars-10440
Note that you must constrain the beam from rotation around its own axis somewhere, in order to avoid a singular stiffness matrix.
The Solid Beam Connection is not intended for this situation.
Henrik
Henrik Sönnerlind
COMSOL
The **Solid Beam Connection** is not intended for this situation.
Henrik
