Newbie question - starting with comsol 4.2
hai,
i just started using comsol, i am going to be working on a high voltage apparatus design project.
i looked through the busbar example. in that, while declaring the parameters for the geometry, is it not possible to 'build all' with the parameters that i input ? that is, without loading from the file mentioned in the tutorial, how do i build a model from the scratch ? this is very vital to me as i will be working on an all new apparatus design soon.
please clarify.
arun
1 Reply Last Post 28.09.2011, 02:28 GMT-4
Posted: 1 decade ago 28.09.2011, 02:28 GMT-4
Maybe you can look at the tutorial with the microactuator.
In this example you will build a geometry using parameters.
Maybe you can look at the tutorial with the microactuator. In this example you will build a geometry using parameters.
