31.08.2011, 09:28 GMT-4
If I have a time dependent model that ran OK say from 0 to 50 microsecs and I wish to continue
the simulation from 50 to 100 microsecs.
How is this done?
thanks
David
Hi David
Not sure if I answer what you are asking for, but if you set your solution as your initial values/start conditions and solve for 50 more microseconds my thought would be that this is what you want.
Nils E
[QUOTE]
How is this done?
thanks
David
[/QUOTE]
Hi David
Nils E
31.08.2011, 10:01 GMT-4
How do you set a solution as an initial start condition?
31.08.2011, 10:30 GMT-4
if you run a first i.e. stationary solver then "store the data" (specific solver node set manually or directly by COMSOL when 2 solvers are added in sequence) and start next solver with the "Stored solution" as "initial conditions" then I believe you have your study sequence
