A strange error message
Dulakshi Karunasinghe
When I try to save a model I just built, I get a strange error:
The object 'Type: List Child tags: ' is not contained in a resource
Also, I get the same message when I try to run the model. I checked all possible things I can think of, but cannot find the cause.
I am running a 3D variably saturated flow problem with Richards equation and an ODE I have defined.
thanks a lot!
6 Replies Last Post 31.08.2011, 19:12 GMT-4
Posted: 1 decade ago 25.07.2011, 12:11 GMT-4
I experienced this error as well. Any new information as to how to resolve it?
Posted: 1 decade ago 25.07.2011, 19:00 GMT-4
Dulakshi,
I ran into the same strange error recently. I deleted some of the more complex features of my geometry and it let me save it just fine. After saving, I went back and rebuilt those features then tried saving again and it worked just fine.
Perhaps this will work for you (if applicable).
-Theodore
Dulakshi, I ran into the same strange error recently. I deleted some of the more complex features of my geometry and it let me save it just fine. After saving, I went back and rebuilt those features then tried saving again and it worked just fine. Perhaps this will work for you (if applicable). -Theodore
Posted: 1 decade ago 25.07.2011, 22:06 GMT-4
I rebuilt the geometry and it worked. Couldn't trace the exact cause though. thanks.
Posted: 1 decade ago 10.08.2011, 04:12 GMT-4
I got this message as well, and I exit the program, and when I tried to reopen the model I got the error message 'File contains no Model' - and now I can't open my model.
I'm running a magnetic field model, and all I changed was add another ampere's law.
I got this message as well, and I exit the program, and when I tried to reopen the model I got the error message 'File contains no Model' - and now I can't open my model. I'm running a magnetic field model, and all I changed was add another ampere's law.
Posted: 1 decade ago 13.08.2011, 14:01 GMT-4
switch to 4.2 or at least check that you have the latest patches, that should help
Hi switch to 4.2 or at least check that you have the latest patches, that should help -- Good luck Ivar
Posted: 1 decade ago 31.08.2011, 19:12 GMT-4
I have the latest patch and version 4.2 and I still get this error.
