Heat transfer from LIQUID to SOLID
I have a simple set up where hot air is flowing into a metal cylinder with a closed end. There are two hole at the side walls near the end of this cylinder, these are for the outlet. Whatever I do, I don't seem to have heat transfer from hot air to this metal cylinder.
When I set air cooler then the metal, I do get heat transfer. But not vice versa...
Any help would be greatly appreciated, thank you in advance
Dogan Sinar
1 Reply Last Post 12.06.2011, 16:56 GMT-4
Posted: 1 decade ago 12.06.2011, 16:56 GMT-4
There have been quite a few updates to the heat transfer model since 4.0 was introduced.
Can you upgrade from 4.0a to 4.2 ? Not to say that will cure your problem, but at least you'll know you are using the most up-to-date formulations.
Regards, John
There have been quite a few updates to the heat transfer model since 4.0 was introduced. Can you upgrade from 4.0a to 4.2 ? Not to say that will cure your problem, but at least you'll know you are using the most up-to-date formulations. Regards, John
