Exporting COMSOL v4.0a data
I got DEP torque on a sphere working (I can see the simulations). However, I am not able to export torque data and even if I export it its giving me a huge txt file with numbers everywhere. In COMSOL 3.5 I was getting X,Y,Z and Torque values systematically in a table format.
Please let me know how to export data systematically in COMSOL v.4.0a.
Thanks with Regards
Prateek
2 Replies Last Post 04.11.2011, 02:23 GMT-4
Hello Prateek Benhal
Posted: 1 decade ago 28.09.2011, 12:20 GMT-4
Have you tried selecting Data Format "Spreadsheet" in Output, under Export--> Data Settings?
Posted: 1 decade ago 04.11.2011, 02:23 GMT-4
Thanks, I got the problem sorted out. (exported data into excel sheet)
May I know if anyone have worked on applying imaginary part to the material in electrostatics?
I am able to get the toqrue output with frequnecy/time, however I am not sure if torque is including complex permittivity factor for the materials?!!
Also I would like to do a time harmonic analysis in electrostatics with a sinusoidal voltage, where v=v0*sin(w*t+phase), However, currently I am able to get the simulations running for only time domain and COMSOL converts this into frequency using fourier transform. I do want to apply varying frequency + varying/complex permittivity for materials in electrostatics and get the torque vs frequency simulations. (I also wanna see the particle torque movement>?>????)
Can someone please guide me on this. Thanks.
Thanks, I got the problem sorted out. (exported data into excel sheet) May I know if anyone have worked on applying imaginary part to the material in electrostatics? I am able to get the toqrue output with frequnecy/time, however I am not sure if torque is including complex permittivity factor for the materials?!! Also I would like to do a time harmonic analysis in electrostatics with a sinusoidal voltage, where v=v0*sin(w*t+phase), However, currently I am able to get the simulations running for only time domain and COMSOL converts this into frequency using fourier transform. I do want to apply varying frequency + varying/complex permittivity for materials in electrostatics and get the torque vs frequency simulations. (I also wanna see the particle torque movement>?>????) Can someone please guide me on this. Thanks.
