A very, very simple problem, little help: calculating magnetic field due to two intensity spots.
Posted 11.05.2011, 11:27 GMT-4 Low-Frequency Electromagnetics Version 4.1 2 Replies
Hello everybody:
I have just bought COMSOL 4.1 with AC/DC Module.
To start to interact with the software, I would like to solve the following problem:
I would like to calculate the magnetic field (B oder H) in the air due to two intensities in a 2D plane.
1) To do this I have chosen as MODEL WIZARD a 2D axisymmetric as space dimension.
2) As GEOMETRY, I have a square with air and inside two points located near the central axis (r=0) and I want to set these two points with two different intensity values (in Ampères,[A]).
3) As MATERIALS, I have used air inside this square.
4) As PHYSICS, I have used the "Magnetic and Electric fields (mef) model".
Now, I need to put the values of these two intensity points and later the boundary values on the square's sides except the one that is located on the axi simmetry (r=0). But I don't have ide how to manage it.
|_______________________|
(r=0)
Above it is represented my domain with the two points of intensity described by *.
Could someone help me, please?
I would be really grateful.
Thanks in advance.
I am looking forward to hearing from you.
Isabel.
(r=0)
Thanks in advance.
Isabel.
2 Replies Last Post 11.05.2011, 12:16 GMT-4
