How to express a local concentration?
Hi guys,
I am doing a simulation about battery. Now I want to get a concentration of certain point(Let's say concentration at x=0 um 1D model) as a variable for a defined function. I am new to comsol, anyone can help me?
2 Replies Last Post 25.06.2012, 12:31 GMT-4
Posted: 1 decade ago 17.05.2011, 23:19 GMT-4
Hi there,
you can define a local variable at that boundary you mentioned. When you define a variable, COMSOL allows you to define wether the variable is calculated over the whole domain or at a boundary.
Good luck on your simulations
Hi there, you can define a local variable at that boundary you mentioned. When you define a variable, COMSOL allows you to define wether the variable is calculated over the whole domain or at a boundary. Good luck on your simulations
Posted: 1 decade ago 25.06.2012, 12:31 GMT-4
I have a similar question regarding concentration at a certain depth. I have 3D model, which shows a cubic soil box. Now I need to use the concentration at z=0(ground surface) for the simulation time. In other words I want to use concentration at (z=0 and t). Based on the answer herein, I tried to define a local variable, but in this way I need to write an expression for this variable. This value should be from Comsol itself which can show c(0,t). How can apply this expression? I will really appreciate your help.
