08.05.2011, 04:58 GMT-4
for "complex" or looping geometry it's worth to mesh manually, by parts, or even launch some seed points on critical edges / surfaces
08.05.2011, 07:54 GMT-4
I agree with mr Ivar. Most of the times with complicated geometries I do mesh manually, however I have always been having problems with seeding a circle or a cylindrical surface.
Comsol uses polynomials to approximate a circle thus if I define the coordinates of a point using the equation of the circumference, the point is always outside the circle. Is there any way to avoid such a drawback? I have trying to change the settings for the approximation but, alas, to no avail!
Cheers
Cheers
08.05.2011, 14:20 GMT-4
I mostly seed a circle by selecting the edge and defining a distribution along this edge (you can even apply a function to the distribution to get uneven increasing or decreasing separations)
09.05.2011, 02:41 GMT-4
Thank you for your replays, they are very helpfull!
I'll try following your suggestions, but unfortunately I'm not so expert in the art of meshing... perhaps you can suggest me same teaching books or papers...
Thaks a lot again!
Roberta
Thaks a lot again!
Roberta
09.05.2011, 03:42 GMT-4
No I do not have any books to propose, but I must say you learn meshing by doing, so follow and try examples passing on the forum, follow the videos, the exercises in the model Library ...
That is the best way, but start simple to get used to the different commands
