Fluid flow boundary condition: what's the difference between the square bracket and the round bracket?
While studying the laminar flow example model from COMSOL model library, the only part I think I am stuck at is the boundary condition expression:
U_mean*6*s*(1-s)*step1(t[1/s])
What's the meaning of the above expression? I understand what's U_mean - it's a variable defined in the global definition (equal to 0.1 in the tutorial pdf). I also understand the function step1 - it's function again defined in the global definitions (it's a simple step function if the tutorial pdf if followed).
What confuses me is the variable "s" and the square brackets in "step1(t[1/s]). I am assuming "t" is simply the time variable.
Please shed some light if you know.
-IMG Comsol
1 Reply Last Post 17.04.2011, 09:36 MESZ
Posted: 1 decade ago 17.04.2011, 09:36 MESZ
if you search the Forum, you will find different explanations around these facts, in 2 word (or a bit more;):
all functions wants unitless variable calls, "t" the time has a unit of seconds, to render it unitless we write t[1/s] and expressed in seconds (this will cancel the "orange writing" warning signal rom COMSOL
"s" is an internal variable defined in 2D and running normally from 0 to 1 along EACH Edge=Boundary in 2D.
It also defines the direction of the edge/boundary see the arrows in edge mode. THe direction is important, as the boundary normal (up-normal) points OUTWARDS from the Domain w.rt. the right hand rule i.e. a vertical Edge with an arrow up (+Y) has its normal to the left (-X) direction hence the Domain it belongs to is to the right !
Then s*(1-s) is a parabola starting and finishing at "0" for s=0 and s=1, this is tyspically the velocity flow of a "non-slip" wall condition. If you integrate s*(1-s) between 0 and 1 you will get 1/6 so U_mean*6*s*(1-s)*step1(t[1/s]) gives you the average velocity at step=1.
THe maximum of s*(1-s) is for s=1/2 with a value of 1/4, hence U_peak*4*s*(1-s)*step1(t[1/s]) is the expression for the o-peak or amplitude value of the velocity, when you know thta one.
Note: in 3D it becomes less evident, "s" no longer exist, it's "s1 s2", they do no longer go from 0 to1 as this depends on the boundary shape. In 3D you must revert to normalised absolute values to express your velocity. Often using the cylindrical coordinates eases the expression.
Finally, I (almost) always add inital conditions for my flow, and always start with a little flow, even if the first step might be with v=0, AS WELL as I add alittle pressure drop to initialise the vectors, this has saved me hours of time waiting for the solver to converge, so I find it very useful.
To check your initial conditions, as these become rapidly complex forskewed geoemtries, you can always right-click on the Solver ... Dependent Variables node and select Compute to Selected. This will load the initial conditions from its default values (or a stored solutionif you chain solvers) and then you have a "Data Set" to probe and analse
Take a look at the models and the explanations in the doc, AND in the Model Library (do not forget to update it with the "update command"
Have fun Comsoling
Hi if you search the Forum, you will find different explanations around these facts, in 2 word (or a bit more;): all functions wants unitless variable calls, "t" the time has a unit of seconds, to render it unitless we write t[1/s] and expressed in seconds (this will cancel the "orange writing" warning signal rom COMSOL "s" is an internal variable defined in 2D and running normally from 0 to 1 along EACH Edge=Boundary in 2D. It also defines the direction of the edge/boundary see the arrows in edge mode. THe direction is important, as the boundary normal (up-normal) points OUTWARDS from the Domain w.rt. the right hand rule i.e. a vertical Edge with an arrow up (+Y) has its normal to the left (-X) direction hence the Domain it belongs to is to the right ! Then s*(1-s) is a parabola starting and finishing at "0" for s=0 and s=1, this is tyspically the velocity flow of a "non-slip" wall condition. If you integrate s*(1-s) between 0 and 1 you will get 1/6 so U_mean*6*s*(1-s)*step1(t[1/s]) gives you the average velocity at step=1. THe maximum of s*(1-s) is for s=1/2 with a value of 1/4, hence U_peak*4*s*(1-s)*step1(t[1/s]) is the expression for the o-peak or amplitude value of the velocity, when you know thta one. Note: in 3D it becomes less evident, "s" no longer exist, it's "s1 s2", they do no longer go from 0 to1 as this depends on the boundary shape. In 3D you must revert to normalised absolute values to express your velocity. Often using the cylindrical coordinates eases the expression. Finally, I (almost) always add inital conditions for my flow, and always start with a little flow, even if the first step might be with v=0, AS WELL as I add alittle pressure drop to initialise the vectors, this has saved me hours of time waiting for the solver to converge, so I find it very useful. To check your initial conditions, as these become rapidly complex forskewed geoemtries, you can always right-click on the Solver ... Dependent Variables node and select Compute to Selected. This will load the initial conditions from its default values (or a stored solutionif you chain solvers) and then you have a "Data Set" to probe and analse Take a look at the models and the explanations in the doc, AND in the Model Library (do not forget to update it with the "update command" -- Have fun Comsoling Ivar
