How a fluid located between a conical cap and conical rod behaves when the cap is seated
Posted 09.04.2011, 14:44 GMT-4 Fluid & Heat 1 Reply
In dentistry we cement crowns to prepared teeth. The teeth have a conical shape and the inside of the crown we cement has the same shape as the prepared tooth. During cementation, the cement is placed inside the crown and the crown is then pressed down on the prepared tooth. During that process, most cement flows away from the crown and leaves a thin film. My intention is to mimic that process, and I wonder if anyone is familiar with a similar problem or have any suggestions how to solve that problem.
Sincerely
Karl-Johan Soderholm
Sincerely
1 Reply Last Post 10.04.2011, 05:45 GMT-4
