Accessing Material Properties outside of Material Node
The below post is related to an archived discussion
[start here]
Hello
I am working on heat transfer probem and want to access to some materail properties: thermal conductivity k for example. But it does not work when I write: mat1.def.k11 I tried a lots: mod1.mat1.def.k11, comp1.mat1.def.k11, mod1.mat1.def.k1, mat1.def.k . . . I have the version 5.3.
Also, the temperature T2 which is an independant variable is not accessible in any expression, while it is accessible in the results part where I can plot it by simply wirting: T2
Thanks for your help!
0 Replies Last Post 09.11.2017, 05:27 GMT-5
Hello Ali Alkurdi
