Magnus Ringh
COMSOL Employee
7 years ago
01.09.2017, 08:25 GMT-4
Hi Toby,
There are several factors that affect the figure contents. I will list three possibilities that might help you to get report images that are better formatted:
- The report image generation is geared toward images with an approximate 4:3 aspect ratio. Perhaps the Graphics window in your COMSOL Multiphysics session uses a different aspect ratio, which may cause some overlap.
- Generally, larger images provide better image quality. In the main Report node's Settings window, you can control the image size under Images. Try increasing the size to Large, for example.
- A third option is to use an Image export node under Results>Export in the model tree. In the settings for the Image node there are several ways to control the image size and the layout of the graphics in the image. You can then include that image in the report by adding an Export node in an existing or new Section of the report. You add it by right-clicking the Section node and choosing Model Contents>Export. In the added Export node, you can control if the image, when it is included in the report, should use the report's size and file format or the referenced image source's formats. Also notice that you can click Preview Selected to check how the image appears in the report without having to regenerate the entire report.
I hope this helps.
Magnus Ringh, COMSOL
Hi Toby,
I hope this helps.
