12.03.2011, 17:23 GMT-5
by the way,
it gives keeping me this error:
the segregated solver do not include all its components . what should I do with segregated solver ?
by the way,
13.03.2011, 05:35 GMT-4
open the segregated solver node and check where the different dependent variables are defined,
Questions to ask:
- are they all there? when you look at each sub node
- are they in the correct order (they may appear twice, that is not necesarily an error)
Questions to ask:
13.03.2011, 12:10 GMT-4
dear Ivar,
when I click on the segregated solver there are two nodes:
segregated step 1 and segregated step 2, the leve lset variable was in non of them. so I add the Phils in the step 1.
so there are mod1_V and Phils in step 1 ,
mod1_u and mod1_p in step 2.
now it gives me this error:
Failed to evaluate variable Jacobian.
- Variable: Vf1_tpf
dear Ivar,
- Variable: Vf1_tpf
13.03.2011, 13:42 GMT-4
without a model its difficult to propose any reasonable action, apart for "Murphy", if not in segregation step 1, perhaps it should be in step 2 ? ;)
The best is to take a working model with the same physics and see how the segregation steps are set up.
Or delete the solver sequence and see how its rebuild itself (valid for v4.1 or newer, not sure it works in V4.0) Note that if you delete the solver sequence it will also delete your Results !! you are warned ;)
