Comsol with Matlab
Posted 24.04.2017, 10:51 GMT-4 Heat Transfer & Phase Change, Computational Fluid Dynamics (CFD), LiveLink for MATLAB Version 5.2a 4 Replies
I saved my comsol model as a matlab file, to run it in matlab using liveLink but then I have this error.
Java exception occurred:
Exception:
com.comsol.util.exceptions.FlException: Invalid property value
(rethrown as com.comsol.util.exceptions.FlException)
Invalid property value.
- Property: p
'Control points' is a matrix of real numbers.
- : Expected size is 2 × (0 – 2147483647).
- : Expected unit is: m.
- Property: p (Control points)
Stack trace:
at com.comsol.clientapi.engine.c.handleException(SourceFile:27)
at com.comsol.client.interfaces.g$d.e(SourceFile:536)
at com.comsol.client.interfaces.g.a(SourceFile:238)
at com.comsol.client.interfaces.ClientWebSocketCommandManager.a(SourceFile:464)
at com.comsol.client.interfaces.g.runAndWait(SourceFile:217)
at com.comsol.clientapi.engine.APIEngine.runMethod(SourceFile:230)
at com.comsol.clientapi.impl.GeomSequenceClient.run(SourceFile:499)
Caused by: Exception:
- Property: p
- : Expected size is 2 (0 2147483647).
at com.comsol.client.interfaces.g.a(SourceFile:378)
at com.comsol.client.interfaces.ClientWebSocketCommandManager.a(SourceFile:485)
at com.comsol.client.interfaces.g.processCommandAnswer(SourceFile:334)
at com.comsol.client.interfaces.g$d.e(SourceFile:534)
... 5 more
- Property: p
at com.comsol.nativeutil.properties.Property.k_(SourceFile:1053)
at com.comsol.nativeutil.properties.Property.d(SourceFile:1046)
at com.comsol.nativeutil.properties.v.check(SourceFile:701)
at com.comsol.nativeutil.properties.Property.getValidDoubleMatrix(SourceFile:553)
at com.comsol.model.internal.impl.PropValueImpl.getDoubleMatrix(SourceFile:747)
at com.comsol.model.internal.impl.PropFeatureImpl.O(SourceFile:2990)
at com.comsol.model.internal.impl.PropFeatureImpl.doGetDoubleMatrix(SourceFile:2907)
at com.comsol.model.internal.impl.PropFeatureImpl.getDoubleMatrix(SourceFile:1945)
at com.comsol.geommesh.geom.PrimBezierPolygon.f(SourceFile:328)
at com.comsol.geommesh.geom.PrimBezierPolygon.doExecute(SourceFile:357)
at com.comsol.geommesh.geom.s.a(SourceFile:616)
at com.comsol.geommesh.geom.s.execute(SourceFile:855)
at com.comsol.model.method.GeomFeatureMethod.build(SourceFile:860)
at com.comsol.model.method.GeomSequenceMethod.build(SourceFile:1944)
at com.comsol.model.method.GeomSequenceMethod.b(SourceFile:1827)
at com.comsol.model.method.GeomSequenceMethod.run(SourceFile:1781)
at com.comsol.model.internal.impl.GeomSequenceImpl.l(SourceFile:4124)
at com.comsol.model.internal.impl.GeomSequenceImpl$21.a(SourceFile:3277)
at com.comsol.model.internal.impl.GeomSequenceImpl$21.execute(SourceFile:1)
at com.comsol.model.clientserver.ClientManager$1.call(SourceFile:169)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
Error in run (line 96)
evalin('caller', [script ';']);
what is the problem !!!
Thank you
Best regards
Exception:
- Property: p
Stack trace:
- Property: p
... 5 more
- Property: p
Thank you
Best regards
4 Replies Last Post 26.04.2017, 05:51 GMT-4
