Joule heating of an alternate current
Posted 07.03.2017, 08:30 GMT-5 Heat Transfer & Phase Change Version 5.2 2 Replies
I am trying to simulate what happens to the temperature of a transmission line that has an alternate current flowing through it. I have the Joule heating physics and I have been able to successfuly simulate the temperature on the line with a direct current. I have applied a voltage on the cable with a ground and a terminal node, and for the AC I tried defining a fasor in the Parameters for the tension appied in the terminal like 1.377*exp(i*(2/3)*pi)[V]. But I son't know if that is the correct way to define an alternate voltage?
Also I was told to use frequency domain study instead of time-dependant. Bu in my case, I want the temperature due to a current of specifically 60Hz, so the frequency domain didn't make much sense to me. Besides, the frequency-domain study doesn' t seem to solve the heating part of the problem, only the eletric currents. Should I use time- dependant?
Thank you in advance for any help,
Luciana
Luciana
2 Replies Last Post 07.03.2017, 09:19 GMT-5
