Plotting results from many values of a certain parameter
Hi all
I have been trying to run my model with a certain parameter changing from one run to another and see how the result looks like in different runs. Is there an easy way of plotting the result of multiple runs other than brute force. What i have been doing is manually change the parameter and store the graph, then change the parameter to a different value and comparing the new result with the old one. Thanks
3 Replies Last Post 26.01.2011, 15:22 GMT-5
Posted: 1 decade ago 26.01.2011, 10:49 GMT-5
in V4.1 you can "duplicate" your nodes, and then just change the equations. Then you can add them to the report to save the files at each run
Hi in V4.1 you can "duplicate" your nodes, and then just change the equations. Then you can add them to the report to save the files at each run -- Good luck Ivar
Posted: 1 decade ago 26.01.2011, 14:19 GMT-5
I will try that. What then is parametric sweep? Does that plot the results by changing the parameter in a user defined way.
Posted: 1 decade ago 26.01.2011, 15:22 GMT-5
you should spend some time studying the different options of the new plotting features in V4.1, there are many options in there, at different levels, for single point or multiple sweep plotting
Hi you should spend some time studying the different options of the new plotting features in V4.1, there are many options in there, at different levels, for single point or multiple sweep plotting -- Good luck Ivar
