Doubt regarding default parameters in COMSOL
Posted 09.01.2017, 07:00 GMT-5 Low-Frequency Electromagnetics, Heat Transfer & Phase Change, Modeling Tools & Definitions, Parameters, Variables, & Functions Version 5.1 2 Replies
Hiii all,
I need to know the way to figure out the available by default output values from different modules which can be used in COMSOL.
To make my statement clear, I am using the magnetic field no current interface and I saw from the code of my senior that he used the value of the field Hx and Hy for calculating magnetic volume force and in the variable section, called these Hx and Hy as mfnc.Hx and mfnc.Hy.
My query is how can I know that Hx and Hy is the output variable from this interface. Where can I see the possible outcomes of a particular module?? Similarly, for heat transfer module, how can I figure out the value of the parameters that I can call further in my code.
How to figure out the default parameters that we can get from different modules in COMSOL and call that later for defining another function?? - ResearchGate. Available from: www.researchgate.net/post/How_to_figure_out_the_default_parameters_that_we_can_get_from_different_modules_in_COMSOL_and_call_that_later_for_defining_another_function [accessed Jan 9, 2017].
2 Replies Last Post 10.01.2017, 03:04 GMT-5
